Do not modify a public listing after you promote it
  • Recommendation: Do not modify a public listing after you promote it to a new lifecycle. Instead, if you encounter an issue with a public listing, delete it or discontinue its use, and create a new one.
  • Rationale: Custom listings become unreliable when they are modified after promotion.
  • Additional information: To make a change to a public listing that you promoted, you can copy the existing listing, and modify the copy.
