Clinical data model installation
The installation process:
Creates or updates a database schema for the model.
Creates or updates database tables based on DMW table metadata if the most recent version is not already installed.
Full installation drops and recreates all tables and deletes all data.
To safeguard your data, full installation is not allowed in the Production lifecycle stage.
Regular installation upgrades tables and does not delete data unless destructive changes have been made to a table. See Destructive and nondestructive changes.
Creates or updates a query that selects all columns and rows from all tables in the model, including any masked data. The system uses this view to display data on the Listings pages.
Checks the compatibility of validation checks and transformations that read from it or write to it. If changes to the model affect a validation check or transformation, the installation process gives a warning. Even if there are no issues, the installation process sets Upgrade to Required for the validation check and transformation to keep all current versions synchronized.
Clinical data models are also installed when the transformation that writes to the model is installed.
