Modify a clinical data model
You can modify an Inform or non-Inform clinical data model. (To add or modify a table manually, see Add or modify a table manually.)
- Modify a non-InForm model
- Modify an InForm input model
- Modify a Clinical One input model
The Clinical One model must have exactly the same table structures as in Clinical One. You cannot make any structural changes. - Upgrade a clinical data model to the latest library version
- Roll back changes to the last production version
Parent topic: Set up clinical data models
