Select internal InForm tables and views for data transformations
Click the Study Configuration icon from the navigation bar. Then click the Clinical Data Models tab.
Select Development from the Lifecycle drop-down at the top of the page.
Select the clinical data model and click Check Out.
Click the Select InForm Operational Data and Metadata Tables icon.
The system displays all InForm tables and views alphabetically. To sort by type, click the heading of the Internal Data Model column. Your administrator makes the default selections. Gray tables and views are required.
Select and deselect until you have selected the tables and views you want for this study.
Save.
Tip:
To ensure that the order of dynamic visits is sequenced properly for each subject in the Subject Summary interface, make sure you select the IRV_SV_SUBJECTVISITS table. For more information about the Subject Summary, see View Subject Summary in the Data Review Guide.Next: Load InForm metadata.
Parent topic: Create a clinical data model for InForm data
