Select packages
If you use free text to write an expression and the expression references a static package or function, you must select the package or function in the Select Packages tab.
- Use the Query By Example fields above the columns to search for the package.
- Select the package(s) you are using in the validation check.
- Click OK.
Next: Add table aliases.
Parent topic: Complete a validation check without a custom program
