Suspend and resume Clinical One data loading
You must suspend data loading to load metadata, install the model, or change the remote location, account, or web service.
  1. Click the Study Configuration icon Icon shows a wrench and a screwdriver, crossed. at the top of any page and then click the Clinical Data Models tab.
  2. Select the lifecycle from the Lifecycle drop-down at the top of the page.
  3. Select the clinical data model.
  4. In the Clinical One Configuration tab, click the Icon is two parallel vertical lines. Suspend icon to stop any scheduled data loads and prevent manually loading data.
    The system replaces the Icon is two parallel vertical lines. Suspend icon with the Icon is a forward arrow triangle. Resume icon.
  5. Click the Icon is a forward arrow triangle. Resume icon to allow manual and scheduled data loading.
