Upgrade transformations to synchronize with models
If there have been metadata changes in a clinical data model—for example, an increase of column length—that affect a transformation or validation check, the system sets the transformation or validation check to Upgrade Required. You must run the upgrade job to synchronize the transformation or validation check with the model.
If the main transformation is checked in, check it out. This automatically upgrades the main transformation and in some cases side transformations too.
If either the main transformation or a side transformation is checked out and its Upgrade Required flag is set to Yes, run the Upgrade job. The Upgrade job for the main transformation may automatically upgrade the side transformation or it may set the side transformation's Upgrade Required flag to Yes, in which case you must run the Upgrade job for the side transformation.
If columns or tables have been removed, mappings may be broken. You must fix these manually.
After upgrade, install the transformation. You can make other changes before installing.
Parent topic: Set up data transformations
