Validation check batch installation
The installation process:
Creates or updates database packages for the generated programs.
Maps the validation check batch to the latest installed version of the source clinical data model.
Creates or updates and installs the target tables to store the discrepant data rows.
Installing a validation check batch does not install the source clinical data model. You cannot install a validation check batch until the source model is installed.
Parent topic: What happens during installation?
