What happens if there's a protocol change?
When metadata changes in InForm, DMW detects it:
During data loading.
When you promote a model to a higher validation status.
When you save changes to a remote location or study account.
The load, promotion, or save is not allowed and a message appears that you need to reload metadata.
You can also run the Compare Metadata report by clicking its icon in the InForm configuration tab, and then import metadata.
Parent topic: FAQs
