Create required InForm users
For each InForm study:
Log in to the system you use to create InForm user accounts:
- If your InForm installation is on-premise, use UMT.
- If your InForm installation is hosted by Oracle, use Single Sign-on.
Create a user with a suggested username DMW_AUTH to be used for authentication purposes by the web service connection. This user does not need any privileges. You enter this username and password when creating web service locations.
Create a user with the required username DMW_QUERY (in UPPER CASE) to be used for sending and updating discrepancies in InForm. Assign this user to a query group. The password for this user is not used in Oracle DMW.
Activate both accounts.
Parent topic: Create users for InForm integration
