DMW Data Blind Break User (Dev, QC, and Prod)
Users with this role can do the following in the corresponding lifecycle stage, if they belong to a user group assigned to the object and in that group have a role with the blinding-related object security privilege noted:
Run a program that reads from currently blinded tables and operates on the real data, not the masked or dummy data (also requires an object security role with the Blind Break operation on Table instances).
View currently blinded data in the user interface (also requires an object security role with the Blind Break operation on Table instances).
View currently blinded data through a visualization tool (requires an object security role with the Blind Break operation on Table instances).
Parent topic: Data Blinding-related application roles
