Enable UI changes for a clinical data system other than InForm
It is possible to integrate a clinical electronic data capture (EDC) system other than InForm with DMW. See Using the Generic Connector to Integrate DMW with a Clinical Data System, My Oracle Support article 2172786.1.
This profile makes changes in the UI required for the integration, including a tab for a new input clinical data model type called External_System Configuration, new actions for sending discrepancies to the external system, and a new web service location type.
- Log in. See Set profiles to determine system behavior.
- In the Profile field, enter
DMW_GC_ON - Click Find.
- In the Site column, set to
OUIto make user interface changes related to the external system integration visible. - In the File menu, select Save and Proceed.
Parent topic: Set profiles to determine system behavior
