Oracle LSH Object Operations
- Application Area: Manage Security
- Domain: Manage Security
- DataModel: Manage Security
- Execution Setup: Modify Val Status to PROD
- Execution Setup: Modify Val Status to QC
- Execution Setup: Submit
- Execution Setup: Manage Security
- Program: Manage Security
- Program: Modify Val Status to PROD
- Program: Modify Val Status to QC
- Program: Modify
- Program: Remove
- Program Instance: Modify Val Status to PROD
- Program Instance: Modify Val Status to QC
- Program Instance: Create Execution Setup
- Program Instance: Remove
- Table: Manage Security
- Table Instance: Manage Security
- Table Instance: Modify
- Table Instance: Remove
- Table Instance: Modify Val Status to QC
- Table Instance: Modify Val Status to PROD
- Table Instance: ReadData
- Table Instance: BlindBreak
- Table Instance: Unblind
- Table Instance: ReadUnblind
- VC Batch: Manage Security
- Work Area: Manage Security
Parent topic: Transformations and Query Builder
