Reasons for change
To enable users to select from a list of predefined reasons for change to discrepancies, add values to the lookup DME_DSC_ACTION_REASON. The access level is User. For each value, add a code and a meaning. The meaning text appears in the user interface as the reason for change.
If you define meaning text that is the same as Reason for Change text in InForm, when an InForm user applies a Reason for Change that is then imported to Oracle DMW, Oracle DMW recognizes that the text is the same and stores the code as well as the meaning. Reasons for change are configurable in InForm as well as DMW.
Parent topic: Set lookup values for Reasons for Change and more
