Use character semantics
On each computer where you install Oracle DMW, you must set the Oracle Applications profile LSH: Use Character Semantics for Workarea Installation to Yes, as instructed in the Oracle Life Sciences Data Hub Installation Guide.
- Log in. See Set profiles to determine system behavior.
- In the Profile field, enter
LSH: Use Character Semantics for Workarea Installation. - Click Find.
- In the Site column, select
YES. - In the File menu, select Save and Proceed.
Parent topic: Set profiles to determine system behavior
