Create a Business Area Hierarchy
Use this API to create a hierarchy in a Business Area. To define the hierarchy's columns, use ModifyBusAreaHierAndHierCol.
Name
CDR_PUB_DF_BUSINESSAREA_HIER.CreateBusinessAreaHier
Signature
PROCEDURE CREATEBUSINESSAREAHIER( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PIO_SOURCECDRNAMING IN OUT CDR_NAMING_VERSION_OBJ_TYPE );
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
PIO_SOURCECDRNAMING (Mandatory) This is a parameter of table type CDR_NAMING_VERSION_OBJ_TYPE.
Enter values for the new hierarchy. Use the NAMESPACE attributes to identify the Business Area in which you want to create the hierarchy.
The following attributes are required: OBJECT_TYPE_RC,NAME,NAMESPACE_OBJ_ID,NAMESPACE_OBJ_VER,OBJECT_SUBTYPE_ID. For OBJECT_TYPE_RC enter $OBJTYPES$BUSAREAHIER.
Parent topic: Create and Modify Business Area Hierarchies
