Enable or Disable Validation Checks
Use this API to enable or disable Validation Checks.
Name
DME_PUB_VALIDATION_CHECK.EnableDisableValidationChecks
Signature
PROCEDURE ENABLEDISABLEVALIDATIONCHECKS (P_API_VERSION IN VARCHAR2, P_INIT_MSG_LIST IN VARCHAR2 DEFAULT CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 DEFAULT CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER DEFAULT CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT NOCOPY VARCHAR2, X_MSG_COUNT OUT NOCOPY NUMBER, X_MSG_DATA OUT NOCOPY VARCHAR2, PI_VC_MAP_COLL IN CDR_BASE_OBJ_COLL, PI_ENABLE_FLAG IN VARCHAR2, );
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
- PI_VC_MAP_COLL (Mandatory). This is a parameter of collection type CDR_BASE_OBJ_COLL that contains CDR base object attributes. The following attributes are required: COMPANY_ID, OBJ_ID, OBJ_VER for Validation Checks maps.
- PI_ENABLE_FLAG (Mandatory). Enter '$YESNO$YES' for enabling and '$YESNO$NO' for disabling.
Parent topic: Create and Modify Validation Checks and Batches
