Get a Subtype Classification Level
Use this API to retrieve all the classification hierarchy levels assigned to an Object Subtype. The function returns a collection of CDR_HIER_LEVEL_VAL_OBJ_TYPE.
Name
CDR_PUB_CLA_SUBTYPES.GetClassificationLevels
Signature
FUNCTION GETCLASSIFICATIONLEVELS( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, PIOBJECTSUBTYPEID IN CDR_OBJECT_SUBTYPES_TL.OBJECT_SUBTYPE_ID%TYPE ) RETURN CDR_HIER_LEVEL_VALUES_COLL;
Return
Type CDR_HIER_LEVEL_VALUES_COLL
Description classification levels.
Parameters
This API has standard parameters (see Standard Parameters) and the following parameter:
PIOBJECTSUBTYPEID Enter the ID of the Object Subtype whose assigned classification levels you want to retrieve.
Parent topic: Classify Subtypes
