Modify a Mapping at the Table Descriptor Level
Use this API to update a mapping at the Table Descriptor level in accordance with all validation rules.
Name
CDR_PUB_DF_MAPPING.ModifyMapping
Signature
PROCEDURE UPDATEMAPPINGCOLUMNS( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PI_MAPPING_COLUMNS IN CDR_MAPPING_COLUMNS_COLL );
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
PI_MAPPING_COLUMNS (Mandatory) This is a collection of CDR_MAPPING_COLUMNS_TYPEs. For each Column that you want to modify, initialize a CDR_MAPPING_COLUMNS_TYPE and then extend the collection. All the attributes are required.
Parent topic: Create and Modify Mappings
