Modify a Validation Check Batch
Use this API to modify a validation check batch.
Name
DME_PUB_VALIDATION_CHECK.UpdateValidationCheckBatch
Signature
PROCEDURE UPDATEVALIDATIONCHECKBATCH ( P_API_VERSION IN VARCHAR2, P_INIT_MSG_LIST IN VARCHAR2 DEFAULT CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 DEFAULT CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER DEFAULT CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT NOCOPY VARCHAR2, X_MSG_COUNT OUT NOCOPY NUMBER, X_MSG_DATA OUT NOCOPY VARCHAR2, PI_BATCHMAPCOMPID IN OUT NOCOPY CDR_NAMINGS.COMPANY_ID%TYPE, PI_BATCHMAPOBJID IN OUT NOCOPY CDR_NAMINGS.OBJ_ID%TYPE, PI_BATCHMAPOBJVER IN OUT NOCOPY CDR_NAMING_VERSIONS.OBJ_VER%TYPE, PI_BATCHNAME IN OUT NOCOPY CDR_NAMINGS.NAME%TYPE, PI_BATCHDESCRIPTION IN CDR_NAMING_VERSIONS.DESCRIPTION%TYPE, PI_ISORDEREDFOREXECUTION IN VARCHAR2, PI_CANBETRIGGERED IN VARCHAR DEFAULT '$YESNO$NO' );
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
- PI_BATCHMAPCOMPID (Mandatory). Enter COMPANY_ID of Validation Checks Batch Map.
- PI_BATCHMAPOBJID (Mandatory). Enter OBJ_ID of Validation Checks Batch Map.
- PI_BATCHMAPOBJVER (Mandatory). Enter OBJ_VER of Validation Checks Batch Map.
- PI_BATCHNAME (Mandatory). Enter Batch Name for new Validation Checks Batch
- PI_BATCHDESCRIPTION (Optional). Enter Batch Description for new Validation Checks Batch.
- PI_ISORDEREDFOREXECUTION (Optional). Enter $YESNO$YES, if Validation Checks under new Batch must be executed in particular order. Otherwise enter $YESNO$NO. If entered as NULL, systems defaults it to $YESNO$NO.
- PI_CANBETRIGGERED (Optional). Enter $YESNO$YES to allow the successful completion of a transformation writing to the clinical data model that this batch runs against to trigger the execution of this batch. Otherwise enter $YESNO$NO. If entered as NULL, systems defaults it to $YESNO$NO.
Parent topic: Create and Modify Validation Checks and Batches
