Remove a Join
Use this API to remove one or more Joins, with all their Columns, from a Business Area.
Name
CDR_PUB_DF_BUSINESSAREA_JOIN.RemoveJoins
Signature
PROCEDURE REMOVEJOINS( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PI_BASEOBJCOLL IN OUT CDR_BASE_OBJ_COLL );
Parameters
This API has standard parameters (see Standard Parameters) and the following parameter:
PI_BASEOBJCOLL (Mandatory) This is a collection of CDR_BASE_OBJ_TYPEs.
For each Join that you want to remove from the Business Area, initialize a CDR_BASE_OBJ_TYPE and then extend the collection.
The following attributes are required: COMPANY_ID,OBJ_ID,OBJ_VER,OBJECT_VERSION_NUMBER,NAMESPACE_OBJ_ID,NAMESPACE_OBJ_VER.
Parent topic: Create and Modify Business Area Joins
