Upgrade Transformation Map
Use this API to upgrade the maps defined at model level.
Name
DME_PUB_XFORM_MAP.UpgradeXformMap
Signature
PROCEDURE UPGRADEXFORMMAPS (P_API_VERSION IN VARCHAR2, P_INIT_MSG_LIST IN VARCHAR2 DEFAULT CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 DEFAULT CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER DEFAULT CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT NOCOPY VARCHAR2, X_MSG_COUNT OUT NOCOPY NUMBER, X_MSG_DATA OUT NOCOPY VARCHAR2 );
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
- PI_XFORMMAPCOMPID (Mandatory). Enter the COMPANY_ID for the transformation map to be upgraded.
- PI_XFORMMAPOBJID (Mandatory). Enter the OBJ_ID for the transformation map to be upgraded.
- PI_XFORMMAPOBJVER (Mandatory). Enter the OBJ_VER for the transformation map to be upgraded.
Parent topic: Create and Modify Transformation Maps
