Upload an Output BLOB
Use this API to upload an output BLOB generated by an external processing engine into Oracle LSH.
Name
CDR_PUB_EXE_EXTERNAL.UploadBlobOutput
Signature
PROCEDURE UPLOADBLOBOUTPUT( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PI_NJOBID IN VARCHAR2, PI_VFILENAME IN VARCHAR2, PI_NPRREFID IN VARCHAR2, PIO_BLOBSTREAM IN OUT BLOB );
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
- PI_NJOBID (Mandatory) Enter the JOB_ID of the job that generated the output.
- PI_VFILENAME (Mandatory) Enter the filename associated with the Planned Output.
- PI_NPRREFID (Mandatory) Enter the PRREF_ID of the Oracle LSH executable. This attribute is available from the cdr_jobs_v view.
- PIO_BLOBSTREAM (Mandatory) This is a parameter of type BLOB. Enter BLOB to be uploaded.
Parent topic: Create and Execute Output LOBs
