Why can't I send a particular data item to another source?
The system uses the preferred path source specified in the transformation or validation check to determine where you can send the discrepancy. If no action is available to send the discrepancy to the right source, you can go to the Listings page, change to the source data model, and create a discrepancy against the data item there.
Add a comment to the current discrepancy detailing what you did.
Parent topic: Acting on a discrepancy FAQs
