Avoid using custom programs
Recommendation: Whenever possible, define a transformation using the DMW user interface, including standard Oracle SQL and custom functions, as opposed to custom programs.
Rationale: If you use custom programs, you are responsible for the coding. This isn't a scalable approach. In addition, custom programs are not as re-usable as transformations that you define in the DMW user interface.
Additional information: For more information about using custom functions, see the Guidance for DMW Implementation and Configuration document.
The only scenario in which we recommend using a custom program is when defining the Filter Drive table, which is marked with the table SUBJECTVISIT SDTM Identifier. In an ideal study design, that is the only custom program used.
Parent topic: Custom programs and functions
