Avoid using the Undo Checkout feature for transformations
Recommendation: Instead of using the Undo Checkout option for a transformation, check the transformation in and then check it out again.
Rationale: When you use the Undo Checkout option, DMW might remove custom functions associated with the transformation. In addition, other issues related to expressions could occur.
Additional information: We recommend tracking all changes as new versions in DMW. You can always roll objects back to their most recent Production version.
Parent topic: Transformations
