Check out the associated transformation when you update a target data model
Recommendation: When you update a target data model, check out its associated transformation as well.
Rationale: When you update a target data model, if check out its associated transformation, DMW automatically upgrades the transformation to use the latest version of the data model. As a result, you do not need to manually upgrade the transformation, and you can easily ensure that the transformation uses the most up-to-date version of the target data model.
Additional information: You are still required to upgrade maps if you modify the transformation's source data models.
Parent topic: Clinical data models
