In DEV and QC, run a full data model installation only to revert destructive changes
Recommendation: When you install data models in the DEV or QC lifecycle, run a full installation only to revert destructive changes.
Rationale: A regular data model installation modifies existing structures, and a full installation performs a drop and recreate action on the structures.
DMW does not allow you to make destructive changes to data models in the Production lifecycle. As a result, you should not need to run a full installation in the Production lifecycle.
Additional information: When you're working in the Production lifecycle, we do not recommend using the full data model installation. However, you might need to run a full data model installation if you made several changes, deletions, or modifications to the data structure in the DEV or QC lifecycle.
When you run a regular installation to install data models, DMW updates or upgrades updated tables. When you run a full installation to install data models:
DMW drops and recreates all tables.
DMW does not drop and recreate the data model schema.
LSH drops and recreates the data model schema.
LSH drops and recreates Business Area (BA) objects.
Parent topic: Clinical data models
