Do not copy a transformation that needs an upgrade
Recommendation: When you copy a transformation from one study to another using the Copy from Another Transformation option, make sure that the transformation you want to copy does not require an upgrade.
Rationale: A transformation that requires an upgrade references old data model definitions. As a result, if you copy it, you'll likely need to perform manual updates to the copy.
Additional information: To further reduce the likelihood that you'll need to make manual changes to the copied transformation, we recommend that you copy transformations that were created by templates or study libraries. However, we also recommend that you manually confirm that the transformation doesn't contain maps that need to be upgraded.
Parent topic: Transformations
