Make sure to select a relevant discrepant column
Recommendation: The discrepant column should always be selected as a column that is present in the listing.
Rationale: When you select the Discrepant Table and Column for a validation check, DMW allows you to select any table and column, not just the ones that make sense in the context of the validation check.
Parent topic: Validation checks
