Specify a static reference for secondary source code
Recommendation: When you add secondary source code to a custom program in LSH, make sure to select Yes for the Static Reference field.
Yes is not selected by default.
Rationale: If you do not specify a static reference, LSH defines a new definition, which is typically not the intent of secondary source code.
Parent topic: Custom programs and functions
