Use the Regenerate program definitions option to rebuild program definitions in a transformation
Recommendation: We recommend that you select Regenerate program definitions when you run a regular transformation installation if you want DMW to rebuild program definitions based on the latest version of the source and target data models in the transformation.
Rationale: If you select Regenerate program definitions when you run a regular transformation installation, DMW does the following:
Rebuilds the program definitions based on the latest version of the source and target data models.
Regenerates portions of the program that were missing prior to the modifications.
Additional information: If you are running a full transformation installation, we recommend that you only select Regenerate program definitions if absolutely necessary.
Parent topic: Transformations
