Can I use a side model like any other model?
Side models are intended for temporary use only and have limitations:
Side models cannot be used as source models for other transformations.
If a validation check raises discrepancies on data in a side model, lineage tracing is not enabled and the discrepancies do not appear in the source model.
Side models are not visible in the Study Configuration page.
Side models and transformations cannot have a higher validation status than Development.
Parent topic: FAQs
