Compare DMW and Clinical One metadata on demand
You can compare the metadata—table and column structure—in any DMW Clinical One model lifecycle stage to any Clinical One lifecycle database for the same study.
  1. After you select a study, click the Study Configuration icon Shows gear with pencil iconfrom the navigation bar. Then click the Clinical Data Model tab.
  2. Select the Clinical One clinical data model.
  3. In the Clinical One Configuration tab, click the Icon is a box with lines.Compare Metadata icon.
  4. In the Metadata Comparison window, select the metadata to compare:
    • For the DMW Clinical One data model: Development, Quality Control, or Production.
    • For Clinical One: Test or Active.
  5. Click Compare. The report appears on screen.
    To save the report, click the Export All to Excel icon.
    If the system finds no differences, a message appears.
