Copy a validation check
- Click the Study Configuration main menu icon
from the navigation bar. Then, click the Validation Checks tab.
- Select the batch where you want to copy a validation check.
- Select Copy Checks from the Checks drop-down.
- Select the project (or other study category), then the study, then the model.
- Select the batch and validation check.
- Click OK.
Parent topic: Manage validation checks
