After you select a study, click Data Management icon from the navigation bar and select Custom Listing
Manager from the drop-down menu to open the Custom Listing Manager
tab.
Click the Add icon from the Custom Listings panel to open the Add Custom Listing
dialog box.
Enter a name for the custom listing in the Name field. Then enter a
description of the new custom listing in the Description field.
Tip:
Use a naming convention and keep names under 25 characters so
data reviewers won't have to scroll to read the name.
Select Authorize access to this listing for users without Blind Break rights if you know that only nonblinded data will be displayed in the listing, even though at least one source table contains blinded data. Take care to select columns that do not contain blinded data.
If any source table is blinded in any way and this setting is not selected, the system blinds the entire target table, so that only users with Blind Break privileges can view any data.
Select Mark as Public to enable all data reviewers to use this custom
listing.
Click Test to verify your custom
listing. After confirming the test results, click
Close.
Click OK to close the dialog box and save the custom
listing with the details you entered. You can return to this procedure
and search for it to continue defining it later.
