Sample programs that populate auxiliary columns with the source surrogate key
The following example SAS and PL/SLQL programs are straightforward ones that you could create in the user interface using a Transformation Type of Direct and Join, respectively. However, they show how to populate auxiliary keys in the target table with the surrogate key value from the source tables.
Parent topic: Create custom programs
