Upgrade validation checks to synchronize with models
If there have been metadata changes in a clinical data model—for example, an increase of column length—that affect a transformation or validation check, the system sets the transformation or validation check to Upgrade Required. You must run the upgrade job to synchronize the transformation or validation check with the model.
Select one or more batches and click the Upgrade Batch icon or reinstall the batch(es).
If columns or tables have been removed, mappings may be broken. You must fix these manually.
When you next install the batch(es), installation ends with a warning if a validation check refers to a table or column that no longer exists in the source model. You must do the synchronization manually.
Parent topic: Manage validation checks
