Why are some validation checks disabled?
Validation checks that read from a table or column marked Not Used are automatically disabled. If the table or column is later marked as Used, you must manually reenable the validation checks to run them.
A person may have manually disabled a validation check to prevent it from running.
To find out why a particular validation check is disabled, hover over the value in the Disabled Reason column.
Parent topic: FAQs
