Modify the display order for field values
You can specify the order in which valid field values appears in the drop-down list for that field.
- In the left navigation pane, click the Settings icon ().
- In the Configure System section, click Manage Topic Workflow Configurations.
- Click the configuration's Row Action menu () for a configuration, and then click Edit.
- Click the Fields card.
- Click the field's Row Action menu (), and then click Define Values.
- Click the Modify Display Order link.
- Use the and keys to move values up and down in the list.
- Click OK.
Parent topic: Manage field values
