Modify the display order of a product field's defined values
In the left navigation pane, click the Settings icon
From the Configure System menu, select Manage
Signal Configurations.
Select the signal configuration and, from its Row Action
menu (), select Edit Product Fields.
From the Row Action menu of the selected product field,
click Define values.
In the top left, click Modify Display Order.
To change the order in which field’s defined values display in the Define
Product Field Values table and in the Add/Edit Product window, click a field
and:
Click to move the defined value up in the list.
Click to move the defined value down in the list.
When the defined values are in the correct order, click
OK.
