Publish a signal configuration
Publishing the signal configuration makes it available to other users. By default, the publication level of every newly created object is Private.
Unless you have the Administer Users permission, you can only publish objects you have created. With the Administer Users permission, you can also publish objects created by any users in your login group.Parent topic: Manage signal configurations
