Step 2: Select a product or group of products to investigate
- Start with the Signal Review Products page
The Products page provides access to a variety of tools and comprehensive alert tracking statistics to conduct your review. - Group and filter products
Using the Products By drop-down list and cards carousel, you can group and filter the products displayed in the Products table. - Find a product in the Products table
Use the Product finder to locate a product in the Products table. - Investigate products in the Products table
The Products table enables you to view and interact with data for individual products. - Focus on a single product from the Products table
Parent topic: Review signal information
