About topics, actions, and the calendar
By selecting Topic Management from the left navigation pane, you can organize and track tables, graphs, and documents related to particular subject matter.
A topic is a way of organizing information about your work assignments
You can set up topics to follow your workflow through different states, such as Initial, Reviewed, and Closed. You can also make topics visible to work teams and assign them to a user or work team.
Topics organize and track tables, graphs, and documents related to a particular subject matter. You can collect and record issues identified through various means, such as automated signal detection, literature reviews, and regulatory requests.
You access topics through the Topic Management page. You must have the View Topics permission and an administrator must set up Oracle Empirica Topics for your use, including making at least one topic workflow configuration accessible to your login group and, if needed, making you a member of work team and assigning work team permissions. For information on setting up the topics feature see Set up Oracle Empirica Topics.
Topics can be made visible to work teams. Visibility controls who can see the topic and its actions. Work team permissions control what type of access a work team member has to a topic or action. Topics and actions are assigned to a user or a work team. At the top of the Topic Management page are the View items for selectors that control the set of topics you can work with.
When a topic transitions to a new state, if the actions were
planned
, Oracle Empirica Topics considers whether to activate the actions and move them to the
initial
state. When actions are moved to the Initial state,
any date field values in the action are populated using the current date and the
date offset from the action type. Oracle Empirica Topics records the action state change in the Action History and sends email
notifications as necessary.
Actions are a way of organizing your work assignments
Within a topic, you can create an action. An action is an activity that has been identified as contributing to the understanding or resolution of a topic. Actions in the Planned state are dormant. These planned actions remain dormant until they are transitioned from the Planned state into the Open state. On the Topic Management page, you have access to topics and actions that you created and those made visible to a work team of which you are a member. You can view them along with other actions in the Topic Actions section of the topic.
Use the calendar to see what you need to do
- List view: The List view provides the list of the available actions. Actions are ordered by Planned Completion Date in ascending order. If more than one action is available on any date, the actions are sorted in alphabetic order.
- Calendar view: The Calendar view displays the available actions on a monthly calendar.
Parent topic: Use Oracle Empirica Topics
