View the Oracle public safety data library
For Cloud environments, Oracle Empirica Signal supports access to the Oracle public safety data library.
If you subscribe to public safety data and Oracle has enabled the data library access for your environment, then users with Manage Configurations permission can access the Manage Subscription Data Releases page. From this page, users can view available data releases and associated release notes and import releases into Oracle Empirica Signal.
If your Oracle Empirica Signal instance is connected to a dedicated Argus Mart server in the Cloud, the Manage Subscription Data Releases page also shows a row listing Argus as a data offering. The import date reflects when the initial connection was established. Data updates happen automatically through the Argus Mart ETL.
The Manage Subscription Data Releases table contains a row for each shared data release you have access to and provides the following information about each release:
Column | Description |
Data Offering |
One of the following values: AERS, Argus, JADER, VAERS, VIGIBASE, or WVAERS. |
Release Name |
The name of the release. |
Description |
Basic information about the data release. |
Release Date |
Date and time that release was available on the shared data server. |
Status |
One of the following values: Available, Cancelled, Error Occurred, In Queue, Loaded, Local, Running, Suspended. |
Product Dictionaries |
If the data configuration specifies product dictionaries, the names and versions of the product dictionaries used by this release. |
Event Dictionaries |
If the data configuration specifies event dictionaries, the names and versions of the event dictionaries used by this release. |
Requested |
Date and time when import of the data release was requested. |
Requested by |
Name of the user who requested the data release be imported. |
Imported |
Date and time when the data release was imported. |
- Manage Subscription Data Releases page options
- To manage the columns in the table, click Columns. For more information, see Arrange table columns.
- To download the table, click Download. For more information, see Download data.
- Row Action menu options
Options available in the Row Action menu vary depending on the data release and status of the row you select.If you click a data release's Row Action menu (), you can do the following:
- To view a PDF version of the Release Notes about a data offering release, click View Release Notes.
- To retrieve a log of the details of the latest import, click View Log. You can print the log.
- To import an available data release, click Import.
- To cancel an import while its status is In Queue or Running, click Cancel. The status changes to Cancelled.
- If the import fails, the status changes to Error Occurred. You can perform the import again by clicking Retry Import.
- To republish a loaded data offering and give all current login groups Read access to the configurations associated with the data release, click Republish.
- For an Argus Mart Data Release, you can refresh dictionaries for all configurations by selecting Refresh Dictionaries.
Parent topic: Manage subscription data releases
