Work with chart options
Click an option at the bottom of a chart to perform the following actions:
- To redraw the chart as a table, bar graph, or pie chart, click Options. From the Chart Options dialog box, select the chart type and click OK.
- To display the notes about the chart below the chart, click +Notes. To hide the notes, click -Notes.
- To display a key below the chart, click +Key. To hide the key, click -Key.
- To determine the default color used for graphs. set the user preferences, Graph Color Palette. You can modify the graph key for your current session on the Choose Graph page for data mining run results.
- To resize the chart, click the diagonal lines in the lower right corner and drag the right and bottom borders to the desired size.
Parent topic: Chart types and options
