Create a case series from drill-down information
On pages and in reports that display a list of cases identified by case ID, you can save the list of cases for future use. The named and saved list of cases is referred to as a case series.
You can also transfer cases to an existing case series.
- In the left navigation pane, hover on the Data Analysis icon (), then click Data Mining Results.
- From the Run name drop-down list, select the run you want to view. Your Default Run user preference determines which run is selected by default.
- Specify selection criteria, and then click View Results Table.
- Click the drug's Row Action menu () whose cases you want to view and select View Cases.
- Click Create Case Series.
- In the Name field, type a name for the new case series. The name does not need to be unique, although Oracle recommends that you use a unique name.
- In the Description field, enter a description of the case series. A default description, which you can modify, might appear.
- To add the case series to a project, click Add to existing project and select the project from the drop-down list of projects associated with objects that you created or that are published to you.
- To create a new project and assign the case series to it, click Add to a new project named and type a project name.
- Click Create.
Parent topic: Drill down through data
