Find a product in the Products table
Use the Product finder to locate a product in the Products table.
Oracle Empirica Signal enables you to quickly find a specific product in the Products table.
To search for a single product:
  1. Click the Find Product icon.
    Find product icon on the Product table
  2. In the Find Product window, find a product by doing one of the following:
    Find Product window
    • Click the arrow to select a product from the list.
    • Start typing to enable the product list autocomplete menu to appear, with product names that contain the characters you enter. When the product you are searching for appears, select it from the list.
    • Enter the name of the product and press Enter.
    The Find Product list matches the products currently displayed in the Products table, including any grouping and filtering you have applied.
    The Products table locates and selects the chosen product. The Details panel updates to display the product information.
