How do I specify hierarchy versions for timestamped data?
If a data configuration supports timestamped data, you must specify a hierarchy version for each time period in the source data. A time period is a range of dates during which only one hierarchy version was used to code the source data.
In the Cloud, Oracle manages the MedDRA versions for connected Oracle Argus Mart configurations. Submit a service request to update MedDRA in Oracle Argus Cloud Service and the associated Oracle Empirica Signal configurations simultaneously.In Oracle Empirica Signal, you must specify the version of MedDRA used to code the source data for each time period. For details, see Specify hierarchy versions for timestamped data.
Parent topic: FAQs
