Modify the display order of product fields
  1. In the left navigation pane, click the Settings icon (Settings icon).
  2. From the Configure System menu, select Manage Signal Configurations.
  3. Select the signal configuration and, from its Row Action menu (Row Action menu icon), select Edit Product Fields.
  4. In the top left corner, click Modify Display Order.
  5. To change the order in which fields display in the Edit Product Fields table and in the Add/Edit Product window, click a field and select one or more fields.
  6. When the fields are in the correct order, click OK.
